はじめに
This repair guide will help if you need to replace the battery of your Asus Q504UA-BHI5T13 laptop. Signs that you should consider replacing the battery are, it no longer holds a charge, or the battery dies very quickly. You should also make sure that the laptop works while it's plugged into power to make sure that the issue is the battery and not another component like the motherboard or hard drive.
When removing the battery, be sure to be very careful as it is very fragile. Also the wires that connect the battery to the laptop itself are very fragile, therefore it is crucial that they are handled with great care.
Before beginning this repair, power down the laptop and disconnect from the power source.
必要な工具と部品
Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
6 の人々がこのガイドを完成させました。
コメント 1 件
Anyone know where to purchase this battery. I’ve ordered off ebay only to get a non-fitting battery and have scoured the internet only to come up empty handed. Any help appreciated.
