メインコンテンツにスキップ
Asus Q503UA-BSI5T17 Hard Drive Removal
必要な工具と部品
  1. Asus Q503UA-BSI5T17 Hard Drive Removal, Battery Replacement: 手順 1、 1の画像 1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 2、 2の画像 1 Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 2、 2の画像 2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 3、 3の画像 1 Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 3、 3の画像 2 Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 3、 3の画像 3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 Hard Drive Removal, Battery: 手順 4、 1の画像 1
    • Remove the five screws holding the battery in place using a Phillips #0 screwdriver.
    • Screw locations are approximate. If you find screws to be located elsewhere, please update this step with their correct locations.
  5. Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 5、 1の画像 1
    • Disconnect the battery connection.
  6. Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 6、 1の画像 1
    • Grab and lift the battery from the top right-hand side.
    • If all screws are removed, it should come out with no struggle at all.
  7. Asus Q503UA-BSI5T17 Hard Drive Removal, Hard Drive: 手順 7、 2の画像 1 Asus Q503UA-BSI5T17 Hard Drive Removal, Hard Drive: 手順 7、 2の画像 2
    • Once you opened the laptop, the hard drive is located on the bottom right from where the battery is.
  8. Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 8、 2の画像 1 Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 8、 2の画像 2
    • Use a Phillips #0 screwdriver to unscrew the four screws surrounding the hard drive.
  9. Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 9、 2の画像 1 Asus Q503UA-BSI5T17 Hard Drive Removal: 手順 9、 2の画像 2
    • Disconnect the cable that is connected to the hard drive by lifting the edge slightly and sliding it horizontally away from the connector.
    • Remove the hard drive.
    • You may need to further remove the metal mounting brackets from your old hard drive then install them on your new hard drive before reinstallation.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Orlando Garcia
メンバー登録日: 08/26/19
359 ポイント
2のガイドは作成済み
チーム
Gateway, Team S1-G4, Saknee Fall 2019 Gateway, Team S1-G4, Saknee Fall 2019人のメンバー
GCC-SAKNEE-F19S1G4
4 メンバー
5のガイドは作成済み
2 件のコメント
Very easy to do. Directions were easy to follow.
Roxann Jackson - 返信
Does this laptop have an M.2 nvme SDD slot?
Isaias Perea - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 12
今までの合計 1,143
