メインコンテンツにスキップ
Asus Q502LA-BSI5T14 Motherboard Replacement
必要な工具と部品
  1. Asus Q502LA-BSI5T14 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 2、 1の画像 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 3、 2の画像 1 Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 3、 2の画像 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 4、 2の画像 1 Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 4、 2の画像 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 6、 2の画像 1 Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 6、 2の画像 2
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 9、 2の画像 1 Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Motherboard Replacement: 手順 10、 1の画像 1
    • Gently lift the motherboard out and away from the laptop.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mary Kounelas
メンバー登録日: 09/25/17
715 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S4G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 16
今までの合計 1,598
