はじめに
The keyboard allows communication between the user and the laptop. If your keyboard is not responding, follow this guide to learn how to replace it.
必要な工具と部品
Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
Remove the one 5 mm Phillips #1 screw.
Pull out the green plastic in order to free the keyboard underneath.
ある他の人がこのガイドを完成しました。
コメント 1 件
Step 4 was misleading. It should have unplugged the cable before lifting the battery. I broke my battery connector off the mobo by following these directions. Lift straight up? That’s silly given how short the battery connection cable is.
