メインコンテンツにスキップ
Asus Q502LA-BSI5T14 Battery Replacement
必要な工具と部品
  1. Asus Q502LA-BSI5T14 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Battery Replacement: 手順 2、 1の画像 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Battery Replacement: 手順 3、 2の画像 1 Asus Q502LA-BSI5T14 Battery Replacement: 手順 3、 2の画像 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Battery Replacement: 手順 4、 2の画像 1 Asus Q502LA-BSI5T14 Battery Replacement: 手順 4、 2の画像 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Mary Kounelas
メンバー登録日: 09/25/17
715 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S4G1
4 メンバー
5のガイドは作成済み
2 件のコメント
Got as far as the removal from wires. How is that done. A total newbie. I just lifted the battery slightly. Would this help with the static or do I totally need to remove the battery? Laptop shows battery is almost fully charged. There is not a green light.
Berta Stoffel - 返信
Mine has no green light at first but after battery reaches full state it is there. However annoyingly flickers (screen and all) between charge state and discharging at full. Luckily seems to work fine across the whole range of charging. Can't believe this Q502LA is still holding on after 8 years :) Wondering if there is any battery drive/update?
jsbenami - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 27
今までの合計 4,469
