メインコンテンツにスキップ
Asus Q501LA-BBI6T03 Wireless Card Replacement
必要な工具と部品
  1. Asus Q501LA-BBI6T03 Wireless Card Replacement, Back Panel: 手順 1、 1の画像 1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Wireless Card Replacement: 手順 2、 1の画像 1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Wireless Card Replacement: 手順 3、 2の画像 1 Asus Q501LA-BBI6T03 Wireless Card Replacement: 手順 3、 2の画像 2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Wireless Card Replacement, Wireless Card: 手順 4、 1の画像 1
    • Pull up on the two metal tabs attached to the card .
    • Unscrew the single 2mm Phillips #0 screw in the top right hand corner.
  5. Asus Q501LA-BBI6T03 Wireless Card Replacement: 手順 5、 1の画像 1
    • Gently slide the card out of its connection ports.
    • Make sure to pull straight out of the connection ports to avoid bending of the card or port.
終わりに
Once finished, follow prerequisite guide in reverse order to finish your repair.
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Aodhan Arias
メンバー登録日: 01/25/17
288 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-1, Banghart Winter 2017 Cal Poly, Team 8-1, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S8G1
3 メンバー
6のガイドは作成済み
2 件のコメント
My Asus Q501L laptop cannot start the wifi card despite having updated the driver and restarting. Troubleshooting returns error Code 10. Did you experience or know how to resolve this problem?
Tony Ly - 返信
Hey there Tony,
I would recommend first checking the status of the hardware device first. You can view a device's status from the device's Properties in Device Manager. It is possible that the driver is corrupted even though it is “updated” fully and could be causing the issue. If so, remove and reinstall the drivers for the device. It could also be that the WiFi card has a hardware issue. There isn’t really anything I know of that you can do besides just replacing it if that’s the case. If it’s new it might be under warrantee but who knows. Unfortunately Code 10 errors are pretty vague and don’t really give a lot of information. Hope this helps.
Aodhan Arias -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 941
