メインコンテンツにスキップ
Asus Q304UA Hard Drive Replacement
必要な工具と部品
  1. Asus Q304UA Hard Drive Replacement, Remove Bottom Cover: 手順 1、 1の画像 1
    • Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
    • Six 9.6 mm screws
    • Four 4.6 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  2. Asus Q304UA Hard Drive Replacement: 手順 2、 3の画像 1 Asus Q304UA Hard Drive Replacement: 手順 2、 3の画像 2 Asus Q304UA Hard Drive Replacement: 手順 2、 3の画像 3
    • Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
    • Be careful not separate the cover too violently or you will risk breaking the plastic clips that are on the bottom cover.
  3. Asus Q304UA Hard Drive Replacement, Disconnect the battery: 手順 3、 3の画像 1 Asus Q304UA Hard Drive Replacement, Disconnect the battery: 手順 3、 3の画像 2 Asus Q304UA Hard Drive Replacement, Disconnect the battery: 手順 3、 3の画像 3
    • Push metal bracket away from battery connector.
    • Use a spudger to push the battery connection straight up.
    • If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
    • Make sure the computer is powered off before removing the battery.
  4. Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 手順 4、 3の画像 1 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 手順 4、 3の画像 2 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 手順 4、 3の画像 3
    • Disconnect the Wifi/Bluetooth RF cables from the wireless card.
    • Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
  5. Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: 手順 5、 2の画像 1 Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: 手順 5、 2の画像 2
    • Pull straight up to disconnect the SATA combo cable from the motherboard.
  6. Asus Q304UA Hard Drive Replacement: 手順 6、 1の画像 1
    • Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
    • Two 2.3 mm screws
    • One 5.6 mm screw
  7. Asus Q304UA Hard Drive Replacement: 手順 7、 3の画像 1 Asus Q304UA Hard Drive Replacement: 手順 7、 3の画像 2 Asus Q304UA Hard Drive Replacement: 手順 7、 3の画像 3
    • Tilt the drive up slightly by the connector
    • Remove the SATA combo connector
  8. Asus Q304UA Hard Drive Replacement: 手順 8、 2の画像 1 Asus Q304UA Hard Drive Replacement: 手順 8、 2の画像 2
    • De-route the SATA and RF cables from the side of the drive bay.
  9. Asus Q304UA Hard Drive Replacement: 手順 9、 1の画像 1
    • Insert wisdom here.
  10. Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: 手順 10、 2の画像 1 Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: 手順 10、 2の画像 2
    • Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
    • Four 3.7 mm screws
  11. Asus Q304UA Hard Drive Replacement: 手順 11、 3の画像 1 Asus Q304UA Hard Drive Replacement: 手順 11、 3の画像 2 Asus Q304UA Hard Drive Replacement: 手順 11、 3の画像 3
    • Peal back thermal cover.
    • Be careful not to tear the cover on the side of the drive as you peel it off.
  12. Asus Q304UA Hard Drive Replacement: 手順 12、 1の画像 1
    • Remove drive from hard drive bracket.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
iHelpU.Tech
メンバー登録日: 08/02/17
3,558 ポイント
5のガイドは作成済み
チーム
iHelpU.tech iHelpU.tech人のメンバー
Business
2 メンバー
16のガイドは作成済み
コメント 1 件
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
Michael Maxson - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 5,121
