はじめに
The Wi-Fi Card is responsible for transmitting data the same way a cell phone or radio does, through radio waves. Your Wi-Fi Card should be able to pick up a signal from the nearby radios using its tiny antennas. If you are having problems with connecting to the internet using your Wi-Fi Card also known as the Local Area Network Card (LAN), you can use this guide to replace your Wi-Fi Card.
必要な工具と部品
To start, turn off the laptop and disconnect the power cable.
Flip the laptop over so the back panel is visible.
もう少しです!
終わりに
