メインコンテンツにスキップ
Asus MeMo Pad 10 ME102A Speaker Replacement
必要な工具と部品
  1. Asus MeMo Pad 10 ME102A Speaker Replacement, Back Panel: 手順 1、 1の画像 1
    • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
    • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
  2. Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 2、 1の画像 1
    • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
  3. Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 3、 1の画像 1
    • After all of the clips have been opened, the back panel should be free to remove by hand
  4. Asus MeMo Pad 10 ME102A Speaker Replacement, Speakers: 手順 4、 1の画像 1
    • The right-hand speaker is labeled ME102A-R and is located by the battery plug. This is the first speaker removed in this guide, however if the left-hand speaker is the only one you need to replace please skip down to the left-hand speaker section.
    • Unplug the speaker cable by gently pushing it parallel to the motherboard with the flat side of the blue plastic opening tool.
  5. Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 5、 1の画像 1
    • Unscrew the M2x4mm screw with the PH00 screwdriver attachment.
  6. Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 6、 1の画像 1
    • Lift the speaker up by the end opposing the steel latch and slide it out from under the steel latch. The speaker has now been removed.
  7. Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 7、 2の画像 1 Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 7、 2の画像 2
    • The left-hand speaker is designated by the lettering ME102A-L and is located by the silver and blue ribbon cable running across the top of the battery.
    • Remove the Ribbon cable labeled CN2 by gently prying up the white latch of the black and white plugs by using the small blue plastic opening tool.
    • Remove the Ribbon cable labeled CN1 by gently prying up the white latch of the black and white plugs by using the small blue plastic opening tool.
  8. Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 8、 1の画像 1
  9. Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 9、 1の画像 1
  10. Asus MeMo Pad 10 ME102A Speaker Replacement: 手順 10、 1の画像 1
終わりに
作成者
2人の作成者と共同で作成されました。
Thian Kraft
メンバー登録日: 08/31/15
113 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 11-3, Blackwell Fall 2016 USF Tampa, Team 11-3, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S11G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 386
