メインコンテンツにスキップ
Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement
必要な工具と部品
  1. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Case: 手順 1、 2の画像 1 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Case: 手順 1、 2の画像 2
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Motherboard: 手順 2、 1の画像 1
    • Working from top to bottom, you will remove all screws with a #000 Phillips head driver, (20) total.
    • (2) screws located in the top corners. NOTE: These screws will be in the speakers.
    • (4) screws located along the top of the battery, (3) along each side of the battery, and (3) along the bottom of the battery.
    • (1) screw in the middle of the motherboard on the side with the orange ribbon cable, (4) screws in the bottom of the motherboard .
  3. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 手順 3、 1の画像 1
    • Make sure that the battery is disconnected from the motherboard by unplugging the ribbon cables.
  4. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 手順 4、 2の画像 1 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Before you remove the entire assembly, first unplug side buttons and cameras from the motherboard using tweezers.
    • The motherboard is easiest to remove simultaneously with the battery. Refer to Step 5 for more details.
  5. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 手順 5、 2の画像 1 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 手順 5、 2の画像 2
    • While the device is open, this is your opportunity to check and see if there is any other damage to the motherboard or other associated parts.
  6. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Facing Camera: 手順 6、 1の画像 1
    • Now carefully pry up the rear facing camera using a spudger.
    • Be careful when using the spudger as you do not want the tool to slip and damage other components of the tablet.
終わりに
作成者
3人の作成者と共同で作成されました。
Anthony Tillett
メンバー登録日: 10/06/16
214 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 5-6, Lacy Fall 2016 USF Tampa, Team 5-6, Lacy Fall 2016人のメンバー
USFT-LACY-F16S5G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 215
