メインコンテンツにスキップ
Asus MeMO Pad 8 ME181C Front Facing Camera Replacement
必要な工具と部品
  1. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement, Rear Case: 手順 1、 2の画像 1 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement, Rear Case: 手順 1、 2の画像 2
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement, Battery: 手順 2、 3の画像 1 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement, Battery: 手順 2、 3の画像 2 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement, Battery: 手順 2、 3の画像 3
    • Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
  3. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 3、 2の画像 1 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 3、 2の画像 2
    • Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
  4. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 4、 2の画像 1 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 4、 2の画像 2
    • Use the pointed end of the nylon spudger to pop up the battery connector.
    • When reconnecting the battery cable after replacing the battery, press the battery connector with your finger until it clicks into place.
  5. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 5、 2の画像 1 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 5、 2の画像 2
    • Use the flat end of the nylon spudger to pry up the battery.
    • The battery is secured with adhesive. Some force is required to detach battery from the device.
    • If removing motherboard is necessary, it may be easier complete this step with the motherboard simultaneously later.
  6. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement, Motherboard: 手順 6、 1の画像 1
    • Working from top to bottom, you will remove all screws with a #000 Phillips head driver, (20) total.
    • (2) screws located in the top corners. NOTE: These screws will be in the speakers.
    • (4) screws located along the top of the battery, (3) along each side of the battery, and (3) along the bottom of the battery.
    • (1) screw in the middle of the motherboard on the side with the orange ribbon cable, (4) screws in the bottom of the motherboard .
  7. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 7、 1の画像 1
    • Make sure that the battery is disconnected from the motherboard by unplugging the ribbon cables.
  8. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 8、 2の画像 1 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Before you remove the entire assembly, first unplug side buttons and cameras from the motherboard using tweezers.
    • The motherboard is easiest to remove simultaneously with the battery. Refer to Step 5 for more details.
  9. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 9、 2の画像 1 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 9、 2の画像 2
    • While the device is open, this is your opportunity to check and see if there is any other damage to the motherboard or other associated parts.
  10. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement, Front Facing Camera: 手順 10、 1の画像 1
    • In the middle of the Motherboard there will be a little ribbon cable (white tab must be lifted to removed cable.)
  11. Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 11、 2の画像 1 Asus MeMO Pad 8 ME181C Front Facing Camera Replacement: 手順 11、 2の画像 2
    • Flip Motherboard assembly over and pick out camera. Now the Front Facing camera can be replaced.
終わりに
作成者
2人の作成者と共同で作成されました。
Anthony Tillett
メンバー登録日: 10/06/16
214 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 5-6, Lacy Fall 2016 USF Tampa, Team 5-6, Lacy Fall 2016人のメンバー
USFT-LACY-F16S5G6
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 5
今までの合計 425
