メインコンテンツにスキップ
はじめに
Use this guide to replace a faulty battery in you ASUS MeMO Pad 8.
パーツ
パーツは指定されていません。
  1. Insert a plastic opening tool into the seam between the rear case and the screen. Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion  Force (ZIF) connector holding the orange motherboard ribbon cable in place. Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion  Force (ZIF) connector holding the orange motherboard ribbon cable in place. Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion  Force (ZIF) connector holding the orange motherboard ribbon cable in place.
    • Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
  3. Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place. Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
    • Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
  4. Use the pointed end of the nylon spudger to pop up the battery connector. When reconnecting the battery cable after replacing the battery, press the battery connector  with your finger until it clicks into place.
    • Use the pointed end of the nylon spudger to pop up the battery connector.
    • When reconnecting the battery cable after replacing the battery, press the battery connector with your finger until it clicks into place.
  5. Use the flat end of the nylon spudger to pry up the battery. The battery is secured with adhesive. Some force is required to detach battery from  the device.
    • Use the flat end of the nylon spudger to pry up the battery.
    • The battery is secured with adhesive. Some force is required to detach battery from the device.
    • If removing motherboard is necessary, it may be easier complete this step with the motherboard simultaneously later.
終わりに
7 の人々がこのガイドを完成させました。
Amy Clarke
メンバー登録日: 2016年05月05日
223 ポイント
2のガイドは作成済み
チーム
iFixit, Team 1-1, Wacker Spring 2016 iFixit, Team 1-1, Wacker Spring 2016人のメンバー
FIX-WACKER-S16S1G1
3 メンバー
4のガイドは作成済み
2 件のコメント
Great instructions and easy disassembly/reassembly. Photos really helped!
Joe Martin - 返信
The time and difficulty for doing this and the me176cx should be the same.
P Schmied - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 4,877
