メインコンテンツにスキップ
Asus MeMO Pad 7 ME170C Front Facing Camera Replacement
必要な工具と部品
  1. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement, Motherboard: 手順 1、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement, Motherboard: 手順 1、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement, Motherboard: 手順 1、 3の画像 3
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 2、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 2、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 2、 3の画像 3
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 3、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 3、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 3、 3の画像 3
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 4、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 4、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 4、 3の画像 3
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 5、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 5、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    購入する
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 6、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 6、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 6、 3の画像 3
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 7、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 7、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 7、 3の画像 3
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 8、 2の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 8、 2の画像 2
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 9、 2の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 9、 2の画像 2
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 10、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 10、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 10、 3の画像 3
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 11、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 11、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 11、 3の画像 3
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 12、 3の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 12、 3の画像 2 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 12、 3の画像 3
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 13、 2の画像 1 Asus MeMO Pad 7 ME170C Front Facing Camera Replacement: 手順 13、 2の画像 2
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
  14. Asus MeMO Pad 7 ME170C Front Facing Camera Replacement, Front Facing Camera: 手順 14、 1の画像 1
    • Gently wedge plastic prying tool underneath top edge of camera.
    • Try not to bend or scratch anything on the motherboard when handling.
    • Pry camera upward away from motherboard.
    • Camera should pop off easily.
終わりに
作成者
2人の作成者と共同で作成されました。
Thomas Brooks
メンバー登録日: 03/04/17
301 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S3-G3, Wilson Spring 2017 IUPUI, Team S3-G3, Wilson Spring 2017人のメンバー
IUPUI-WILSON-S17S3G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 12
今までの合計 211
