メインコンテンツにスキップ
Asus MeMO Pad 7 ME170C Ribbon Cable Replacement
必要な工具と部品
  1. Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement, Ribbon Cable: 手順 1、 3の画像 1 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement, Ribbon Cable: 手順 1、 3の画像 2 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement, Ribbon Cable: 手順 1、 3の画像 3
    • Before beginning to disassemble, power off the device.
    • Be gentle with the screen of the device. Excessive force can damage it.
    • Using the Jimmy tool, pry it into the seam of the device.
    • With the Jimmy tool, pry open the device through the seam.
  2. Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 2、 3の画像 1 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 2、 3の画像 2 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 2、 3の画像 3
    • Locate the black bundle cable connector attached to the battery.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Use the blue plastic opening tool to loosen the black bundle cable connector Loosen it in a back and forth motion towards the battery.
  3. Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 3、 3の画像 1 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 3、 3の画像 2 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 3、 3の画像 3
    • Use the plastic opening tool to loosen the battery by using the edges.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 4、 3の画像 1 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 4、 3の画像 2 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 4、 3の画像 3
    • Use the wide nosed tweezers to remove the yellow tape that secures the bottom end of the ribbon cable. Gently lift the edge of the tape.
  5. Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 5、 3の画像 1 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 5、 3の画像 2 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 5、 3の画像 3
    • Using wide nosed tweezers, pinch the blue tab attached to the ribbon cable towards the top of the device that is inserted in the mother board.
    • Pull the ribbon cable firmly. However, do not rip it out.
    • In a lateral motion, pull the blue tab gently.
    • At the bottom of the device, use wide nosed tweezers to pinch the opposite blue tab of the ribbon cable.
  6. Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 6、 3の画像 1 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 6、 3の画像 2 Asus MeMO Pad 7 ME170C   Ribbon Cable Replacement: 手順 6、 3の画像 3
    • The middle of the ribbon will be glued down to the device.
    • Heat the iOpener in the microwave for one minute.
    • After heating, vertically place the iOpener on top of the ribbon cable. Let it sit for one minute.
    • Remove the iOpener.
    • Use the wide nosed tweezers to pinch the ribbon cable from the middle. Pull it up firmly to detach. Be careful not to rip it off.
終わりに
作成者
6人の作成者と共同で作成されました。
Tatiana Schneider
メンバー登録日: 10/04/15
599 ポイント
4のガイドは作成済み
チーム
Eastern Washington University, Team 2-3, Plummer Fall 2015 Eastern Washington University, Team 2-3, Plummer Fall 2015人のメンバー
EWU-PLUMMER-F15S2G3
5 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,064
