メインコンテンツにスキップ
Asus M51E-B2 Troubleshooting Hard Drive Replacement
必要な工具と部品
  1. Asus M51E-B2 Troubleshooting Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 1 Asus M51E-B2 Troubleshooting Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 2
    • Before you proceed, make sure you have properly backed up or transferred the data from your old hard disk drive.
    • Use a Phillips #0 screwdriver to remove the two 2.5 millimeter screws holding the section of the case together.
    • Slide the case off of the hard drive section.
  2. Asus M51E-B2 Troubleshooting Hard Drive Replacement: 手順 2、 2の画像 1 Asus M51E-B2 Troubleshooting Hard Drive Replacement: 手順 2、 2の画像 2
    • Once you have removed the section of the case covering the hard drive, you will see a metal cover over the hard drive.
    • Remove the four 2.5 millimeter screws on each cover of the hard drive cover. (Be sure to have a safe place to put them, as they are small and are easily lost.)
    • Once you have removed the screws holding the hard drive cover in place, pull on the plastic tab until the cover comes off. The cover is on tracks, so be sure to pull horizontally in order to avoid damaging your computer.
  3. Asus M51E-B2 Troubleshooting Hard Drive Replacement: 手順 3、 3の画像 1 Asus M51E-B2 Troubleshooting Hard Drive Replacement: 手順 3、 3の画像 2 Asus M51E-B2 Troubleshooting Hard Drive Replacement: 手順 3、 3の画像 3
    • Now that you have removed the hard drive cover, you are able to remove the hard drive itself.
終わりに
作成者
3人の作成者と共同で作成されました。
Chris C
メンバー登録日: 09/21/18
147 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S8-G2, Riccardelli Fall 2018 University of North Texas, Team S8-G2, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S8G2
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 29
今までの合計 483
