メインコンテンツにスキップ
Asus Laptop K43SA A43SA Thermal compound Replacement
必要な工具と部品
  1. Asus Laptop K43SA A43SA Thermal compound Replacement, Thermal compound: 手順 1、 1の画像 1
    • Don't forget to remove the battery and back up your data before processing.
  2. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 2、 1の画像 1
    • Remove the two philips screws from the cover.
  3. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 3、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 3、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 3、 3の画像 3
    • We can see different elements in here :
    • Wifi card
    • Hard drive
    • Ram memory
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
  4. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 4、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 4、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 4、 3の画像 3
    • Remove the single screw from the wireless card.
    • Remember the position of the cables. Here the white cable is on the top of the wifi card.
  5. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 5、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 5、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 5、 3の画像 3
    • Remove the four screws from the hard drive cage.
    • Then slide the cage to the left.
    • Finally, remove the hard drive.
  6. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 6、 2の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 6、 2の画像 2
    • Remove the four M2X8 screws.
    • Remove the single M2X4 screw.
    • Remove the two M2.5X12 screws just below the battery
    • Remove the other four screws at each side, next to the battery.
  7. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 7、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 7、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 7、 3の画像 3
    • With a flathead screwdriver, push the clips in order to release the keyboard.
    • The keyboard is held by glue. Remove it carefully.
    • The keyboard's cable is just below the keyboard. Gently Remove the keyboard by lifting its upper part.
  8. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 8、 2の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 8、 2の画像 2
    • Now we are going to remove the keyboard connector.
    • Push gently each side of the black part of the connector with a pick.
  9. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 9、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 9、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 9、 3の画像 3
    • Then we are going to remove the other two cables.
    • It's a bit different here. You will have to lift up the black part of the connector ( with an opening pick) , and then pull the cable.
    • Be careful, when you reconnect this kind of cables. You can see in the second picture that there is a marker. The black line on the cable is aligned with the white line on the motherboard. This indicates that the cable is properly inserted into the connector.
  10. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 10、 2の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 10、 2の画像 2
    • Proceed the same way for that one.
  11. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 11、 2の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 11、 2の画像 2
    • Then remove all the M2X8 screws.
  12. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 12、 2の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 12、 2の画像 2
    • Now you can easily remove the DVD/CD drive.
    • Just below the DVD/CD drive, there are two little screws to remove.
  13. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 13、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 13、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 13、 3の画像 3
    • You can now remove the brown metallic cover by inserting a pick underneath. You'll have to insert the pick all around the cover in order to remove it.
    • We now have access to the motherboard.
  14. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 14、 1の画像 1
    • Remove this cable the same way than the step 9 and 10.
  15. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 15、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 15、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 15、 3の画像 3
    • For this screen's cable you will have to proceed the same way than the step 8 with the keyboard's cable. Push gently each side of this cable to release it.
    • Then remove the little one.
  16. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 16、 2の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 16、 2の画像 2
    • To completely release the motherboard, remove this two screws.
    • You will notice that there is a little arrow indicating the location of the screw to remove.
    • You can now easily remove the motherboard from the case.
  17. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 17、 1の画像 1
    • Here we are ! The motherboard is now fully released.
    • There are two elements in here:
    • The CPU.
    • The GPU.
    • Disconnect the fan cable.
  18. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 18、 1の画像 1
    • Remove the four screws from the GPU.
  19. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 19、 1の画像 1
    • Remove the four screws from the CPU.
  20. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 20、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 20、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 20、 3の画像 3
    • When the cooler is removed from the motherboard you can notice the dried up thermal paste.
    • Clean both surfaces with alcohol and paper towels.
    • Do not remove the pink thermal pads.
  21. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 21、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 21、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 21、 3の画像 3
    • We are now going to clean the fan.
    • Use a flathead screwdriver to unclip the grey part of the fan.
    • And...you will notice a disastrous amount of dust stuck into the cooler.
    • This dust is largely responsible for the overheating and excessive noise from the laptop.
    • Take a vacuum cleaner and a brush and clean everything.
  22. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 22、 3の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 22、 3の画像 2 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 22、 3の画像 3
    • Scratch the old thermal paste from the surface of the CPU with a pick or a plastic opening tool .
    • Use alcohol, q-tips and paper towel to completely remove the residual traces of thermal paste on the CPU.
  23. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 23、 2の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 23、 2の画像 2
    • Proceed the same way for the GPU.
  24. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 24、 1の画像 1
    • This is time to replace the old paste with a new one. Buy a good quality paste to ensure a proper heat dissipation.
  25. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 25、 1の画像 1
    • "Put a small drop ( 4-5 mm diameter) of thermal paste onto the centre of the heat-spreader."
    • This is actually the usage instructions from Noctua.
  26. Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 26、 2の画像 1 Asus Laptop K43SA A43SA Thermal compound Replacement: 手順 26、 2の画像 2
    • It's almost done!
    • Replace the cooler on the CPU and GPU by slightly moving in all directions to spread the thermal paste.
    • Screw the cooler.
    • Do not forget to reconnect the fan cable.
    • Reassemble the laptop and.... enjoy the silence of the computer!
終わりに
17 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
jpl2288
メンバー登録日: 05/18/14
811 ポイント
1ガイドが承認済み
3 件のコメント
Wow! BEST Step by Step Instruction Guide ever seen by far.... this guide just saved me almost $50 or more service charge if i had relied from a IT tech. Thanks men!
acemanok3000 - 返信
pls also let me know how fix the screen there seems to be loose connection my laptop get white scree when i move hinges
Abd-AlHAkeem SK - 返信
Apply light pressure to the right of the asus logo (while you are facing the screen), and about an inch from the edge of the screen. This is usually where the connector to the screen is. Hope you solve it as I did mine,
niko tolentino -
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 36
今までの合計 14,348
