はじめに
If your Asus K55VD has experienced sudden screen crashing, the blue screen of death, or abnormal noises within its system, then you must have a faulty hard drive. Before replacing the hard drive, make sure you save your data and completely turn the device off. Put each removed component into a safe location.
必要な工具と部品
Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
After removing the screws, remove the smaller cover.
3 の人々がこのガイドを完成させました。
