はじめに
If a computer's fan is faulty, there will likely be overheating error messages occurring. If overheating does occur, the CPU could be damaged.
必要な工具と部品
手順1 Battery
注意: 手順 1 は、作業進行中としてマークされている ガイド から引用されています。
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
After removing the screws, remove the smaller cover.
Remove all 12 screws from the bottom cover with a Phillips #0 screwdriver.
The single screw in the middle of the bottom cover is shorter than the rest.
You should also unscrew the bottom silver screw and unplug the wifi antennas.
7 の人々がこのガイドを完成させました。
2 件のコメント
At step 5, you should also unscrew the bottom silver screw and unplug the wifi antennas.
