Flip the laptop over, such that the bottom of the laptop is facing upwards.
Ensure that the laptop is powered off prior to following this guide.
While holding the second latch from the previous step, use another hand to reach underneath the battery.
Pull the battery upwards and away from the laptop to remove it.
Using the card that has been inserted in the top of the screen follow the edge of the screen all the way down to each corner touching the keyboard.
Some of the clips may break.
If the cover is not being held by just the bottom, go around the screen again to ensure all of the clips have been popped.
Using the card to loosen the remaining clasps inside the screen cover, remove the cover from the back plate and screen.
If the cover does not come off of the screen and back plate easily, the cover may be stuck to the hinge. (This is usually due to dirt or grime)
Pull up on the tape holding down the ribbon connector.
Using the brown colored part of the cable pull the cable out of the connection point
The connection point is delicate, try to pull straight back and away from the connection point.
Using a JIS #00 screwdriver, unscrew the six 2.5 mm screws while holding the bracket to the screen on the sides.
The screen should be easily removed when all of the screws are taken out.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
