メインコンテンツにスキップ
はじめに
If you need to access laptop internals such as the RAM, hard drive, or the motherboard, this guide will show you how to safely open the laptop for access to these components.
パーツ
パーツは指定されていません。
  1. Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Pull the latch to the right of the battery to the right. Pull the latch to the right of the battery to the right.
    • Pull the latch to the right of the battery to the right.
  3. Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing. Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. While holding the second latch from the previous step, use another hand to reach underneath the battery. Pull the battery upwards and away from the laptop to remove it.
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel. Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Remove the panel by pushing away from the laptop until the panel is free of the laptop. Lift to remove the panel. Lift to remove the panel.
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
終わりに
ある他の人がこのガイドを完成しました。
Elliott Beckner
メンバー登録日: 2018年11月05日
543 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S2-G1, Baechle Fall 2018 IUPUI, Team S2-G1, Baechle Fall 2018人のメンバー
IUPUI-BAECHLE-F18S2G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 240
