メインコンテンツにスキップ
はじめに
If you wish to replace or upgrade the RAM inside your ASUS K55N, this is the guide for you.
パーツ
パーツは指定されていません。
  1. Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Pull the latch to the right of the battery to the right. Pull the latch to the right of the battery to the right.
    • Pull the latch to the right of the battery to the right.
  3. Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing. Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. While holding the second latch from the previous step, use another hand to reach underneath the battery. Pull the battery upwards and away from the laptop to remove it.
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel. Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Remove the panel by pushing away from the laptop until the panel is free of the laptop. Lift to remove the panel. Lift to remove the panel.
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
  7. Lift up the plastic static shield atop the RAM slots. Lift up the plastic static shield atop the RAM slots.
    • Lift up the plastic static shield atop the RAM slots.
  8. Depress the tongs on either side of the RAM stick to loosen the RAM from the slot. Depress the tongs on either side of the RAM stick to loosen the RAM from the slot.
    • Depress the tongs on either side of the RAM stick to loosen the RAM from the slot.
  9. Grab the RAM and pull away from the slot to release it. Grab the RAM and pull away from the slot to release it.
    • Grab the RAM and pull away from the slot to release it.
終わりに
ある他の人がこのガイドを完成しました。
Elliott Beckner
メンバー登録日: 2018年11月05日
543 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S2-G1, Baechle Fall 2018 IUPUI, Team S2-G1, Baechle Fall 2018人のメンバー
IUPUI-BAECHLE-F18S2G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 230
