メインコンテンツにスキップ
Asus K55N-DS81 Hard Drive Replacement
必要な工具と部品
  1. Asus K55N-DS81 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Asus K55N-DS81 Hard Drive Replacement: 手順 2、 2の画像 1 Asus K55N-DS81 Hard Drive Replacement: 手順 2、 2の画像 2
    • Pull the latch to the right of the battery to the right.
  3. Asus K55N-DS81 Hard Drive Replacement: 手順 3、 2の画像 1 Asus K55N-DS81 Hard Drive Replacement: 手順 3、 2の画像 2
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. Asus K55N-DS81 Hard Drive Replacement: 手順 4、 2の画像 1 Asus K55N-DS81 Hard Drive Replacement: 手順 4、 2の画像 2
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Asus K55N-DS81 Hard Drive Replacement, Rear Panel: 手順 5、 2の画像 1 Asus K55N-DS81 Hard Drive Replacement, Rear Panel: 手順 5、 2の画像 2
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Asus K55N-DS81 Hard Drive Replacement: 手順 6、 3の画像 1 Asus K55N-DS81 Hard Drive Replacement: 手順 6、 3の画像 2 Asus K55N-DS81 Hard Drive Replacement: 手順 6、 3の画像 3
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
  7. Asus K55N-DS81 Hard Drive Replacement, Hard Drive: 手順 7、 1の画像 1
    • Using a JIS #00 screwdriver, unscrew the four 5 mm screws fastening the hard drive enclosure to the laptop.
  8. Asus K55N-DS81 Hard Drive Replacement: 手順 8、 3の画像 1 Asus K55N-DS81 Hard Drive Replacement: 手順 8、 3の画像 2 Asus K55N-DS81 Hard Drive Replacement: 手順 8、 3の画像 3
    • Grab the plastic tab located on the hard drive enclosure.
    • Pull the tab towards yourself, the hard drive will slide towards you as it disconnects from the motherboard.
    • Lift the enclosure by the tab to remove the enclosure from the laptop.
  9. Asus K55N-DS81 Hard Drive Replacement: 手順 9、 2の画像 1 Asus K55N-DS81 Hard Drive Replacement: 手順 9、 2の画像 2
    • Using a JIS #00 screwdriver, unscrew the four 3 mm screws securing the hard drive to the enclosure.
    • Do not forget to flip the enclosure over and unscrew the screws on the other side.
  10. Asus K55N-DS81 Hard Drive Replacement: 手順 10、 2の画像 1 Asus K55N-DS81 Hard Drive Replacement: 手順 10、 2の画像 2
    • Grab the hard drive and pull it away from the enclosure to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Elliott Beckner
メンバー登録日: 11/05/18
543 ポイント
4のガイドは作成済み
チーム
IUPUI, Team S2-G1, Baechle Fall 2018 IUPUI, Team S2-G1, Baechle Fall 2018人のメンバー
IUPUI-BAECHLE-F18S2G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 17
今までの合計 466
