はじめに
This guide will instruct you on how to properly remove the optical drive.
必要な工具と部品
Place your laptop face down in front of you.
Slide the button in the top right corner to the right so that the orange marker is showing.
Press the spring loaded latch to release the battery from the computer.
Insert the spudger into the indent near the "ESC" key.
Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
On the back of the laptop unscrew the eighteen 5mm Phillips #1 screws.
Unscrew the two 5mm Phillips #1 screws.
