メインコンテンツにスキップ
はじめに
Replacing the hard drive on this device is quite easy as all of the components are accessible by removing a single cover.
  1. First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
    • First, turn off your laptop, then disconnect the power supply. Unplug any peripheral devices connected to your laptop.
    • Next, remove the battery from the laptop.
    • In the picture, the battery is not installed.
  2. Next, remove the 4 Phillips screws from the service door cover (circled in red). In this photo, the screws have already been removed.
    • Next, remove the 4 Phillips screws from the service door cover (circled in red).
    • In this photo, the screws have already been removed.
  3. Remove the 4 screws circled in red in the photo. Once the screws are removed, slide the hard drive to the right, with the help of the tab.
    • Remove the 4 screws circled in red in the photo.
    • Once the screws are removed, slide the hard drive to the right, with the help of the tab.
  4. Remove the 4 screws located on the side of the support. Then, remove the hard drive form its metallic support. Finally, replace de hard drive with a new one or an SSD.
    • Remove the 4 screws located on the side of the support.
    • Then, remove the hard drive form its metallic support.
    • Finally, replace de hard drive with a new one or an SSD.
終わりに
To reassemble your device, follow these steps in reverse order.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
Brendan
メンバー登録日: 2016年09月24日
21,582 ポイント
1ガイドが承認済み
3 件のコメント
why do you do this?
Carl Jefferson - 返信
You can do this to replace a faulty hard-drive or replace it by a SSD to get better performance. So I did this to replace mine by a new one and I wrote this guide for other people who search how to do it. As you can see, very easy to do.
Brendan -
Amazing tutorial, thanks :)
Jérémy Martin - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 859
