この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Charging port pieces inside of the laptop may get damaged and not allow it to charge. This guide will help you replace the charging port inside the ASUS K50IJ.
必要な工具と部品
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
ある他の人がこのガイドを完成しました。
コメント 1 件
Cool really nice guide. If I could rate I would give it a 5 but I got one question. How tf do I put it back together now?
