はじめに
Charging port pieces inside of the laptop may get damaged and not allow it to charge. This guide will help you replace the charging port inside the ASUS K50IJ.
必要な工具と部品
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
Slide the motherboard to the right and lift it up, but do not pull it completely out.
Flip the laptop back over. The charging port will be located in the top-right corner.
Step 30 — there are THREE cables (2 ribbon and 1 modular) attached to the face of the motherboard that you cannot see until it’s been removed.
Scot Young - 返信
Yes indeed, thanks Scot.
Also this guide forgets to remove all the screws around the outside edge, to remove the top cover Step 37. 7 screws by my count. 4 on I/O side, 3 on DVD side
Nick Cowan - 返信
Also Step 33 removing hinges, requires the pictured screw on top of each, as well as 2 underneath each hinge
Nick Cowan - 返信
ある他の人がこのガイドを完成しました。
コメント 1 件
Cool really nice guide. If I could rate I would give it a 5 but I got one question. How tf do I put it back together now?
