メインコンテンツにスキップ
Asus K50I Thermal Paste Replacement and Fan Cleaning
必要な工具と部品
  1. Asus K50I Thermal Paste Replacement and Fan Cleaning, Opening the back panel.: 手順 1、 3の画像 1 Asus K50I Thermal Paste Replacement and Fan Cleaning, Opening the back panel.: 手順 1、 3の画像 2 Asus K50I Thermal Paste Replacement and Fan Cleaning, Opening the back panel.: 手順 1、 3の画像 3
    • Remove the battery.
    • Remove the screws from behing, that hold the back panel.
  2. Asus K50I Thermal Paste Replacement and Fan Cleaning, The insides.: 手順 2、 3の画像 1 Asus K50I Thermal Paste Replacement and Fan Cleaning, The insides.: 手順 2、 3の画像 2 Asus K50I Thermal Paste Replacement and Fan Cleaning, The insides.: 手順 2、 3の画像 3
    • Once you open the back panel, it should look like this. Now is a good time to upgrade the HDD and RAM.
    • Disconnect the fan connector and unscrew it with the cooling assembly.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
    • Now is a good idea to upgrade the CPU.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order to ensure even pressure. Dont forget to plug in the fan cable.
  3. Asus K50I Thermal Paste Replacement and Fan Cleaning, Cleaning the fan.: 手順 3、 3の画像 1 Asus K50I Thermal Paste Replacement and Fan Cleaning, Cleaning the fan.: 手順 3、 3の画像 2 Asus K50I Thermal Paste Replacement and Fan Cleaning, Cleaning the fan.: 手順 3、 3の画像 3
    • Remove the 4 screws that hold the fan assembly together.
    • Clean all the mess inside and reassemble.
    • Apply new thermal paste and you are done.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Simeon Brankov
メンバー登録日: 11/08/20
7,252 ポイント
54のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 164
