はじめに
This guide outlines how to replace the display assembly for the Asus GL551JW-AH71.
必要な工具と部品
Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
Remove the three 5mm screws located in each circle with a Phillips #000 screwdriver.
A total of twelve 5mm screw should be removed in order to free the display assembly from the base.
3 の人々がこのガイドを完成させました。
