メインコンテンツにスキップ
Asus G75VW-BHI7N07 Trackpad Buttons Replacement
必要な工具と部品
  1. Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 手順 1、 3の画像 1 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 手順 1、 3の画像 2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: 手順 1、 3の画像 3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 2、 3の画像 1 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 2、 3の画像 2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 2、 3の画像 3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 3、 2の画像 1 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 3、 2の画像 2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 4、 2の画像 1 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 4、 2の画像 2
    • Take off the henge cover using the opening tool.
    • Remove the 2 black outside edge (9 mm) screws with the J0 Phillips screwdriver.
  5. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 5、 3の画像 1 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 5、 3の画像 2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 5、 3の画像 3
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands.
    • Remove all electrical connections using your hands.
  6. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 6、 2の画像 1 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: 手順 6、 2の画像 2
    • Take the 2 (3 mm) screws out of the trackpad using the PH1 Phillips screwdriver.
    • Remove the trackpad buttons using your hands.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Tai Dean
メンバー登録日: 09/08/17
173 ポイント
1ガイドが承認済み
チーム
Western Carolina University, Team S1-G1, Virtue Fall 2017 Western Carolina University, Team S1-G1, Virtue Fall 2017人のメンバー
WCU-VIRTUE-F17S1G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 1,309
