はじめに
The optical drive can wear out over time or stop working completely. This guide will show you how to remove the optical assembly on the side of the device.
必要な工具と部品
If you have power, press the eject button.
If you don't have power, use the opening tool to pry off the disk drive cover.
Press the Manual Eject button with the spudger and the disk drive should slide out. (Might need tweezers if it doesn't pop out immediately)
Once the disc drive pops out, flip the laptop over.
ある他の人がこのガイドを完成しました。
