メインコンテンツにスキップ
Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement
必要な工具と部品
  1. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Battery: 手順 1、 1の画像 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 手順 2、 1の画像 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 手順 3、 1の画像 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: 手順 4、 2の画像 1 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: 手順 4、 2の画像 2
    • Remove the rubber stoppers in the top left and right corners to expose two 9mm Phillips #00 screws. Unscrew and remove them.
    • Unscrew and remove the three 4mm Phillips #00 screws inside the battery compartment.
  5. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 手順 5、 1の画像 1
    • Carefully turn the laptop right-side up.
    • Using an opening tool, pry the outer edges of the hinge cover up and away from the laptop.
    • The hinge cover, located at the back of the laptop, is the long plastic plate that covers the hinges and speakers.
  6. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 手順 6、 3の画像 1 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 手順 6、 3の画像 2 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 手順 6、 3の画像 3
    • Without disconnecting the speaker cable, set the hinge cover upside-down.
    • Hold the speaker cable by its white connector, then pull to unplug it from the motherboard.
    • You may need to apply some force, as these connectors can be difficult to unplug.
  7. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 手順 7、 1の画像 1
    • The speaker is attached to the hinge cover by four 3.5mm Phillips #00 screws. Unscrew and remove them.
  8. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: 手順 8、 1の画像 1
    • Lift the speaker to remove it.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Stephanie Asling
メンバー登録日: 10/05/17
424 ポイント
2のガイドは作成済み
チーム
Portland State University, Team S1-G1, Read Fall 2017 Portland State University, Team S1-G1, Read Fall 2017人のメンバー
PSUN-READ-F17S1G1
2 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 720
