メインコンテンツにスキップ
Asus G750JW-BBI7N05 Hard Drive Replacement
必要な工具と部品
  1. Asus G750JW-BBI7N05 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Hard Drive Replacement: 手順 2、 1の画像 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Hard Drive Replacement: 手順 3、 1の画像 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Hard Drive Replacement, Hard Drive: 手順 4、 2の画像 1 Asus G750JW-BBI7N05 Hard Drive Replacement, Hard Drive: 手順 4、 2の画像 2
    • Lift up the rubber stopper on the backplate to expose one Phillips #00 screw. Unscrew it until it becomes loose.
    • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the lower case from the laptop.
    • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
  5. Asus G750JW-BBI7N05 Hard Drive Replacement: 手順 5、 1の画像 1
    • Use an opening tool to pry up the backplate along its edges, then remove it.
    • You may need to apply some force when prying up the backplate.
    • Keep in mind: During reassembly, replace the backplate starting from the bottom.
  6. Asus G750JW-BBI7N05 Hard Drive Replacement: 手順 6、 2の画像 1 Asus G750JW-BBI7N05 Hard Drive Replacement: 手順 6、 2の画像 2
    • On the left metal hard drive casing, unscrew and remove the indicated three 4mm Phillips #00 screws.
    • The right hard drive casing is for optional secondary hard drives.
  7. Asus G750JW-BBI7N05 Hard Drive Replacement: 手順 7、 2の画像 1 Asus G750JW-BBI7N05 Hard Drive Replacement: 手順 7、 2の画像 2
    • Use the black tab as leverage to slide the metal hard drive casing all the way to the left.
    • Still holding the black tab, pull the hard drive casing up to remove it from the laptop.
  8. Asus G750JW-BBI7N05 Hard Drive Replacement: 手順 8、 1の画像 1
    • Unscrew and remove the four 4mm Phillips #00 screws around the metal casing. Each side has two screws.
    • Slide the hard drive out of its metal casing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Siyuan Yan
メンバー登録日: 10/05/17
131 ポイント
1ガイドが承認済み
チーム
Portland State University, Team S1-G1, Read Fall 2017 Portland State University, Team S1-G1, Read Fall 2017人のメンバー
PSUN-READ-F17S1G1
2 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 17
今までの合計 2,267
