メインコンテンツにスキップ
Asus G750JW-BBI7N05 Display Replacement
必要な工具と部品
  1. Asus G750JW-BBI7N05 Display Replacement, Battery: 手順 1、 1の画像 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Display Replacement: 手順 2、 1の画像 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Display Replacement: 手順 3、 1の画像 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Display Replacement, Display: 手順 4、 1の画像 1
    • Place your laptop in the upright and open position.
  5. Asus G750JW-BBI7N05 Display Replacement: 手順 5、 1の画像 1
    • Remove the four 4mm Phillips #00 screws from the four corners of the display.
  6. Asus G750JW-BBI7N05 Display Replacement: 手順 6、 1の画像 1
    • Gently pry the front bezel away from the screen and back bezel with an opening tool.
    • The bezel is the outside plastic frame surrounding the screen.
    • You will feel and hear the bezel "unsnap" as you move the pry tool around the entire display.
  7. Asus G750JW-BBI7N05 Display Replacement: 手順 7、 1の画像 1
    • As you work, be mindful of other components that surround the screen, like the WiFi antenna, Bluetooth, webcam, and microphone.
    • Remove the six 6mm Phillips #00 screws across the top of the screen and the four 6mm Phillips #00 screws at the bottom of the screen.
  8. Asus G750JW-BBI7N05 Display Replacement: 手順 8、 1の画像 1
    • With the screws removed, the metal bracket surrounding the screen will feel loose.
    • Remove the top bracket by pulling upwards on the tabs.
  9. Asus G750JW-BBI7N05 Display Replacement: 手順 9、 1の画像 1
    • Remove the four 3mm Phillips #00 screws from the sides of the screen.
  10. Asus G750JW-BBI7N05 Display Replacement: 手順 10、 1の画像 1
    • With the screen free, tilt it gently forward to reveal the display data cable.
    • Unplug the display data cable by peeling off the clear sticker covering its connector, then pulling this connector out of its socket.
    • Make sure to only peel off the sticker that covers the display data cable connector.
  11. Asus G750JW-BBI7N05 Display Replacement: 手順 11、 2の画像 1 Asus G750JW-BBI7N05 Display Replacement: 手順 11、 2の画像 2
    • Remove the two side brackets from the sides of the screen by removing the six 3mm Phillips #00 screws attaching it. There are three screws on either side of the screen.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sandy Jewell
メンバー登録日: 10/05/17
342 ポイント
2のガイドは作成済み
チーム
Portland State University, Team S1-G1, Romaine Spring 2018 Portland State University, Team S1-G1, Romaine Spring 2018人のメンバー
PSUN-ROMAINE-S18S1G1
7 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 2,258
