メインコンテンツにスキップ
Asus G74SX-BBK7 Trackpad Button Replacement
必要な工具と部品
  1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: 手順 1、 1の画像 1
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 Trackpad Button Replacement: 手順 2、 1の画像 1
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Asus G74SX-BBK7 Trackpad Button Replacement: 手順 3、 2の画像 1 Asus G74SX-BBK7 Trackpad Button Replacement: 手順 3、 2の画像 2
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
  4. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: 手順 4、 1の画像 1
    • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
  5. Asus G74SX-BBK7 Trackpad Button Replacement: 手順 5、 1の画像 1
    • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
    • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
    • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
  6. Asus G74SX-BBK7 Trackpad Button Replacement: 手順 6、 2の画像 1 Asus G74SX-BBK7 Trackpad Button Replacement: 手順 6、 2の画像 2
    • Next, pry open back plastic cover using a metal spudger.
    • Unscrew the four 10mm Phillips #0 screws under the cover.
  7. Asus G74SX-BBK7 Trackpad Button Replacement: 手順 7、 3の画像 1 Asus G74SX-BBK7 Trackpad Button Replacement: 手順 7、 3の画像 2 Asus G74SX-BBK7 Trackpad Button Replacement: 手順 7、 3の画像 3
    • Lay laptop opened and completely flat.
    • Using the metal spudger, slowly pry open the front main panel by going around each side.
    • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
    • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
  8. Asus G74SX-BBK7 Trackpad Button Replacement: 手順 8、 2の画像 1 Asus G74SX-BBK7 Trackpad Button Replacement: 手順 8、 2の画像 2
    • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
    • Remove the mouse button.
  9. Asus G74SX-BBK7 Trackpad Button Replacement: 手順 9、 3の画像 1 Asus G74SX-BBK7 Trackpad Button Replacement: 手順 9、 3の画像 2 Asus G74SX-BBK7 Trackpad Button Replacement: 手順 9、 3の画像 3
    • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
    • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
    • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryan Lawrence
メンバー登録日: 04/14/15
611 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S5G10
4 メンバー
6のガイドは作成済み
コメント 1 件
Where did you find the part?
websmiths - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 22
今までの合計 4,810
