はじめに
If you are experiencing problems with your computer's screen like cracking or dead pixels, you will likely need to replace it. With this guide, you will learn how to take apart your Asus G74SX-BBK7 for a screen replacement step-by-step.
必要な工具と部品
Begin by removing the six square rubber pads around the edge of the frame. These cover the screws to remove the outer frame. They can be taken out by hand or with a pair of tweezers.
Next, remove the six 6mm Phillip #0 screws from the frame using a Phillips #0 screwdriver.
4 の人々がこのガイドを完成させました。
コメント 1 件
I replace a motherboard in computer AND W0NT SHOW 0N THE SCREEN BUT IT DOSE TURN ON
