メインコンテンツにスキップ
Asus G74SX-BBK7 Screen Replacement
必要な工具と部品
  1. Asus G74SX-BBK7 Screen Replacement, Screen: 手順 1、 2の画像 1 Asus G74SX-BBK7 Screen Replacement, Screen: 手順 1、 2の画像 2
    この手順で使用する道具:
    購入する
    • Begin by removing the six square rubber pads around the edge of the frame. These cover the screws to remove the outer frame. They can be taken out by hand or with a pair of tweezers.
    • The squares are attached by a light adhesive which may need to be replaced if it wears off due to constant removal
    • Next, remove the six 6mm Phillip #0 screws from the frame using a Phillips #0 screwdriver.
  2. Asus G74SX-BBK7 Screen Replacement: 手順 2、 1の画像 1
    • Use a spudger to remove the frame. It should come off easier at the top than the bottom so start at the top and work your way down.
    • Be careful when prying off frame so as not to damage the screen or the frame itself.
  3. Asus G74SX-BBK7 Screen Replacement: 手順 3、 2の画像 1 Asus G74SX-BBK7 Screen Replacement: 手順 3、 2の画像 2
    • Remove the two 6mm Phillips #0 screws from the top left and right corners using a Phillips #0 screwdriver.
    • Gently lift the top bracket off of the screen and set it aside.
  4. Asus G74SX-BBK7 Screen Replacement: 手順 4、 3の画像 1 Asus G74SX-BBK7 Screen Replacement: 手順 4、 3の画像 2 Asus G74SX-BBK7 Screen Replacement: 手順 4、 3の画像 3
    • Repeat the last step with the bottom bracket, removing eight 6 mm Phillips #0 screws using a Phillips #0 screwdriver. Set the bracket aside.
  5. Asus G74SX-BBK7 Screen Replacement: 手順 5、 3の画像 1 Asus G74SX-BBK7 Screen Replacement: 手順 5、 3の画像 2 Asus G74SX-BBK7 Screen Replacement: 手順 5、 3の画像 3
    • Remove four 6mm Phillips #0 screws from the hinges at the bottom of the screen using a Phillips #0 screwdriver.
    • The top section of the laptop will no longer be attached, so gently lay it back on the table.
  6. Asus G74SX-BBK7 Screen Replacement: 手順 6、 2の画像 1 Asus G74SX-BBK7 Screen Replacement: 手順 6、 2の画像 2
    • Remove the two 6mm Phillips #0 screws on either side of the screen using a Phillips #0 screwdriver.
  7. Asus G74SX-BBK7 Screen Replacement: 手順 7、 2の画像 1 Asus G74SX-BBK7 Screen Replacement: 手順 7、 2の画像 2
    • Remove the screen from the laptop casing and flip it over. Peel the sticker above the connector back and firmly pull the connector out.
  8. Asus G74SX-BBK7 Screen Replacement: 手順 8、 2の画像 1 Asus G74SX-BBK7 Screen Replacement: 手順 8、 2の画像 2
    • The last step is to remove eight 3mm Phillip #0 screws from both side brackets of the screen itself using a Phillips #0 screwdriver. There are four screws on each side.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Ryan Lawrence
メンバー登録日: 04/14/15
611 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S5G10
4 メンバー
6のガイドは作成済み
コメント 1 件
I replace a motherboard in computer AND W0NT SHOW 0N THE SCREEN BUT IT DOSE TURN ON
nicholasvotolato - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 14
今までの合計 2,164
