メインコンテンツにスキップ
はじめに
This guide will teach you how to replace the optical drive in your Asus. An optical drive is responsible for reading media discs like CDs and DVDs, so knowing how to replace it is important. If your computer won't properly read discs or is not functioning, you may need to replace the optical drive. This guide will give you the tools to do so.
  1. Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Lastly, use a plastic opening tool to remove the optical drive from its slot. Lastly, use a plastic opening tool to remove the optical drive from its slot.
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
終わりに
4 の人々がこのガイドを完成させました。
Ryan Lawrence
メンバー登録日: 2015年04月14日
608 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S5G10
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 1,880
