メインコンテンツにスキップ
Asus G55VW DS71 Sound Bar Replacement
必要な工具と部品
  1. Asus G55VW DS71 Sound Bar Replacement, Battery: 手順 1、 2の画像 1 Asus G55VW DS71 Sound Bar Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
  2. Asus G55VW DS71 Sound Bar Replacement, Keyboard: 手順 2、 2の画像 1 Asus G55VW DS71 Sound Bar Replacement, Keyboard: 手順 2、 2の画像 2
    • Find the panel on the back of the computer. Use a Phillips #0 screwdriver to unscrew the 2 4.2mm screws on that panel. Next, lift up the panel at the indent and place it aside.
  3. Asus G55VW DS71 Sound Bar Replacement: 手順 3、 1の画像 1
    • When the back panel is removed, disconnect the blue and black ribbon connectors exposed from the back panel.
  4. Asus G55VW DS71 Sound Bar Replacement: 手順 4、 1の画像 1
    • Remove the fifteen 4.2 mm screws on the bottom of the laptop with a Phillips #0 screwdriver, under the battery, and beneath the back panel that secure the keyboard to the laptop.
    • The top-left and upper center screws are difficult to reach with the iFixit screw kit.
  5. Asus G55VW DS71 Sound Bar Replacement: 手順 5、 2の画像 1 Asus G55VW DS71 Sound Bar Replacement: 手順 5、 2の画像 2
    • Begin to pry the keyboard off of the laptop with the pointed metal spudger.
    • It is possible to damage yourself as well as the device with the metal spudgers. Exercise extreme caution.
  6. Asus G55VW DS71 Sound Bar Replacement: 手順 6、 3の画像 1 Asus G55VW DS71 Sound Bar Replacement: 手順 6、 3の画像 2 Asus G55VW DS71 Sound Bar Replacement: 手順 6、 3の画像 3
    • Remove the ribbon connectors that connect the keyboard to the motherboard. The keyboard should now be completely disconnected from the laptop.
  7. Asus G55VW DS71 Sound Bar Replacement, Sound Bar: 手順 7、 2の画像 1 Asus G55VW DS71 Sound Bar Replacement, Sound Bar: 手順 7、 2の画像 2
    • Remove the panel by popping it off.
  8. Asus G55VW DS71 Sound Bar Replacement: 手順 8、 2の画像 1 Asus G55VW DS71 Sound Bar Replacement: 手順 8、 2の画像 2
    • Use a Phillips #00 screwdriver to unscrew 3 screws on the audio board.
  9. Asus G55VW DS71 Sound Bar Replacement: 手順 9、 1の画像 1
    • Lift the audio board and find the 2 wires connecting it to the computer.
    • Pull on those wires to disconnect them .
終わりに
作成者
2人の作成者と共同で作成されました。
Blake Cangolosi
メンバー登録日: 09/26/18
178 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S7-G7, Thompson Fall 2018 University of North Texas, Team S7-G7, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S7G7
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 254
