はじめに
If you need to replace the motherboard of your Asus G55VW DS71 laptop, follow this guide.
It's an important part of your system, but getting to know when to upgrade your motherboard isn't always easy. Although replacing the motherboard can be costly, it can provide you with benefits in terms of speed, hardware support, and improved graphics support.
Prior to beginning the repair, be sure to power off your laptop and unplug it from the charging cord.
ツール
パーツ
パーツは指定されていません。
Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
Find the panel on the back of the computer. Use a Phillips #0 screwdriver to unscrew the 2 4.2mm screws on that panel. Next, lift up the panel at the indent and place it aside.
Placing your hand on the side of the disk drive closest to the motherboard, slightly push down and out to remove the drive.
In this step, remove the nine 4.2 mm screws that hold the motherboard to the laptop itself using the Phillips #0 screwdriver.
Take the motherboard gently from the laptop.
