メインコンテンツにスキップ
Asus G55VW DS71 Motherboard Replacement
必要な工具と部品
  1. Asus G55VW DS71 Motherboard Replacement, Battery: 手順 1、 2の画像 1 Asus G55VW DS71 Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
  2. Asus G55VW DS71 Motherboard Replacement, Keyboard: 手順 2、 2の画像 1 Asus G55VW DS71 Motherboard Replacement, Keyboard: 手順 2、 2の画像 2
    • Find the panel on the back of the computer. Use a Phillips #0 screwdriver to unscrew the 2 4.2mm screws on that panel. Next, lift up the panel at the indent and place it aside.
  3. Asus G55VW DS71 Motherboard Replacement: 手順 3、 1の画像 1
    • When the back panel is removed, disconnect the blue and black ribbon connectors exposed from the back panel.
  4. Asus G55VW DS71 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove the fifteen 4.2 mm screws on the bottom of the laptop with a Phillips #0 screwdriver, under the battery, and beneath the back panel that secure the keyboard to the laptop.
    • The top-left and upper center screws are difficult to reach with the iFixit screw kit.
  5. Asus G55VW DS71 Motherboard Replacement: 手順 5、 2の画像 1 Asus G55VW DS71 Motherboard Replacement: 手順 5、 2の画像 2
    • Begin to pry the keyboard off of the laptop with the pointed metal spudger.
    • It is possible to damage yourself as well as the device with the metal spudgers. Exercise extreme caution.
  6. Asus G55VW DS71 Motherboard Replacement: 手順 6、 3の画像 1 Asus G55VW DS71 Motherboard Replacement: 手順 6、 3の画像 2 Asus G55VW DS71 Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the ribbon connectors that connect the keyboard to the motherboard. The keyboard should now be completely disconnected from the laptop.
  7. Asus G55VW DS71 Motherboard Replacement, Disk Drive: 手順 7、 1の画像 1
    • Placing your hand on the side of the disk drive closest to the motherboard, slightly push down and out to remove the drive.
  8. Asus G55VW DS71 Motherboard Replacement, Motherboard: 手順 8、 1の画像 1
    • In this step, remove the nine 4.2 mm screws that hold the motherboard to the laptop itself using the Phillips #0 screwdriver.
    • Take the motherboard gently from the laptop.
  9. Asus G55VW DS71 Motherboard Replacement: 手順 9、 2の画像 1 Asus G55VW DS71 Motherboard Replacement: 手順 9、 2の画像 2
    • In order to get to some screws on the motherboard, the monitor needs to be moved.
    • On the right side of the computer there should be a panel that is connecting the monitor to the computer. Use a Phillips #0 screwdriver to remove each screw.
  10. Asus G55VW DS71 Motherboard Replacement: 手順 10、 2の画像 1 Asus G55VW DS71 Motherboard Replacement: 手順 10、 2の画像 2
    • Pull out the 2 wires connecting the monitor to the computer.
  11. Asus G55VW DS71 Motherboard Replacement: 手順 11、 1の画像 1
    • Push the monitor away in order to clear up space for the 2 screws and unscrew them.
  12. Asus G55VW DS71 Motherboard Replacement: 手順 12、 1の画像 1
    • Disconnect the black and white wires from the motherboard slowly.
  13. Asus G55VW DS71 Motherboard Replacement: 手順 13、 2の画像 1 Asus G55VW DS71 Motherboard Replacement: 手順 13、 2の画像 2
    • Before taking the motherboard out, make sure that all the screws were removed. Then, remove the motherboard from the body of the laptop gently.
    • The exhaust vent for the fans are snapped into the body of the laptop. Exercise caution when removing the motherboard.
終わりに
作成者
6人の作成者と共同で作成されました。
Andres Santiesteban
メンバー登録日: 09/26/18
375 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S7-G7, Thompson Fall 2018 University of North Texas, Team S7-G7, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S7G7
3 メンバー
6のガイドは作成済み
コメント 1 件
Great post , I'm getting a second hand laptop like this. This really help. Thank you.
Lim Lim - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 15
今までの合計 1,466
