この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
必要な工具と部品
Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
Find the panel on the back of the computer. Using a Phillips #0 screwdriver, unscrew the 2 4.2mm screws on that panel. Lift up the panel at the indent and place it aside.
ある他の人がこのガイドを完成しました。
