はじめに
Replacing the trackpad on the Asus G501JW-BHI7N12 is a repair that can be done even by new/ low experienced fixers. Should a trackpad become unable, it can make simple task very difficult. Removing the trackpad for a replacement saves you a lot of time, that is normally lost when you sent the laptop out to a repair shop.
必要な工具と部品
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Remove the four 7.0mm Philips #0 screws around the battery.
Attach an anti static wrist strap to your hand and clip to the laptop case.
Using the Phillips #0 screwdriver, remove the six 5 mm screws located along the copper heat sink.
Using the Phillips #0 screwdriver, remove the three 4 mm screws attached to the trackpad.
