メインコンテンツにスキップ
Asus G501JW-BHI7N12 Trackpad Replacement
必要な工具と部品
  1. Asus G501JW-BHI7N12 Trackpad Replacement, Battery: 手順 1、 2の画像 1 Asus G501JW-BHI7N12 Trackpad Replacement, Battery: 手順 1、 2の画像 2
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Attach the clip of your anti-static wrist strap to the case of the laptop. This prevents any accidents that could fry the motherboard.
    • Remove the four 7.0mm Philips #0 screws around the battery.
  2. Asus G501JW-BHI7N12 Trackpad Replacement: 手順 2、 1の画像 1
    • Unplug the connector highlighted in this picture by pulling it up and out of it's seating, then pull the battery away from the motherboard and remove the battery.
  3. Asus G501JW-BHI7N12 Trackpad Replacement, Cooling Fan: 手順 3、 1の画像 1
    この手順で使用する道具:
    $7.95
    購入する
  4. Asus G501JW-BHI7N12 Trackpad Replacement: 手順 4、 1の画像 1
    • Unscrew and remove the four 5mm Phillips #0 screws from the cooling fan.
  5. Asus G501JW-BHI7N12 Trackpad Replacement: 手順 5、 1の画像 1
    • Remove 4 pin connector from mother board.
  6. Asus G501JW-BHI7N12 Trackpad Replacement: 手順 6、 1の画像 1
    • Slide cooling fan out from underneath the copper heat sink.
    • The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
  7. Asus G501JW-BHI7N12 Trackpad Replacement: 手順 7、 1の画像 1
    • One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
  8. Asus G501JW-BHI7N12 Trackpad Replacement, Motherboard: 手順 8、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the six 5 mm screws located along the copper heat sink.
  9. Asus G501JW-BHI7N12 Trackpad Replacement: 手順 9、 1の画像 1
    • Using the same Phillips #0 screwdriver, remove the nine 4 mm screws located around the motherboard.
  10. Asus G501JW-BHI7N12 Trackpad Replacement: 手順 10、 1の画像 1
    • Gently remove the motherboard.
  11. Asus G501JW-BHI7N12 Trackpad Replacement, Trackpad: 手順 11、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws attached to the trackpad.
  12. Asus G501JW-BHI7N12 Trackpad Replacement: 手順 12、 1の画像 1
    • Gently remove the trackpad from its slot.
終わりに
作成者
2人の作成者と共同で作成されました。
Timothy Goike
メンバー登録日: 02/18/21
277 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 171
