はじめに
If you are careful, the touch pad can be easily replaced. All you need is a #0 Phillips screwdriver and plastic opening tool to open the Asus notebook and remove your current touch pad. Before beginning this project, you should make sure that your notebook is not simply in need of a reboot. Also, before beginning your project, you need to shut down your note book and remove its charging cord.
必要な工具と部品
Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
もう少しです!
終わりに
