メインコンテンツにスキップ
Asus EeeBook X205TA Motherboard Replacement
必要な工具と部品
  1. Asus EeeBook X205TA Motherboard Replacement, Motherboard: 手順 1、 2の画像 1 Asus EeeBook X205TA Motherboard Replacement, Motherboard: 手順 1、 2の画像 2
    • Unscrew all 10 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Motherboard Replacement: 手順 2、 1の画像 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Motherboard Replacement: 手順 3、 2の画像 1 Asus EeeBook X205TA Motherboard Replacement: 手順 3、 2の画像 2
    • Unscrew all seven screws around the outer edge of the motherboard using 2mm Phillips Screwdriver.
  4. Asus EeeBook X205TA Motherboard Replacement: 手順 4、 2の画像 1 Asus EeeBook X205TA Motherboard Replacement: 手順 4、 2の画像 2
    • Unplug the No-Fuss Ribbon battery, screen, and speakers from the motherboard.
    • Carefully remove the ZIF screen connector.
    Voir le commentaire de Sebastian Swirski pour les branchements des 8 câbles
    https://ibb.co/jcgwUQ
    RepairGuy - 返信
終わりに
10 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Shahir Makary
メンバー登録日: 10/06/16
294 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S2G2
3 メンバー
10のガイドは作成済み
3 Guide Comments
Very clear and precise instructions. Thanks
wdkandler - 返信
Here is a more detailed view of all the cables that have to be unplugged before the motherboard can be extracted: https://ibb.co/jcgwUQ
Also, be aware that, even after all screws and cables are removed, it will still require a little bit of force to remove the motherboard, due to the thermal adhesive on the CPU and GPU. Do not be afraid to pull the motherboard! As long as you followed the instructions and disconnected all the EIGHT cables and SEVEN screws, you are not going to damage anything, it’s just thermal tape!
Sebastian Swirski - 返信
I guess because if the spill damage, the motherboard stop my keyboard from working and the usual from
Tayler Grant - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 50
今までの合計 7,138
