はじめに
This guide will help you replace your Asus EeeBook X205TA motherboard in case it is damaged, you want a faster RAM, better data transfers or better graphics. If disposing motherboard , please follow the laws and regulations for proper disposal.
必要な工具と部品
Unscrew all 10 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Unplug the No-Fuss Ribbon battery, screen, and speakers from the motherboard.
Carefully remove the ZIF screen connector.
Voir le commentaire de Sebastian Swirski pour les branchements des 8 câbles
10 の人々がこのガイドを完成させました。
3 件のコメント
Here is a more detailed view of all the cables that have to be unplugged before the motherboard can be extracted: https://ibb.co/jcgwUQ
Also, be aware that, even after all screws and cables are removed, it will still require a little bit of force to remove the motherboard, due to the thermal adhesive on the CPU and GPU. Do not be afraid to pull the motherboard! As long as you followed the instructions and disconnected all the EIGHT cables and SEVEN screws, you are not going to damage anything, it’s just thermal tape!
I guess because if the spill damage, the motherboard stop my keyboard from working and the usual from
