はじめに
This guide will help you replace your Asus EeeBook X205TA LED panel chip if it is damaged. If disposing of the LED chip, please follow the laws and regulations for proper disposal.
必要な工具と部品
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Locate and lift the tabs from the LED/motherboard ribbon cable.
Remove the cable.
もう少しです!
終わりに
