Unscrew all 10 screws located on the bottom of the laptop using a Phillips #2 Screwdriver.
Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
Carefully pry open the case from several points.
Slowly remove the back of the laptop, revealing the parts inside.
The USB ports are located on the strip that looks like the motherboard on the left side of the laptop next to the battery.
Unscrew the four screws using Philips #2 screwdriver located around the edge of the USB ports.
Unplug the battery ZIF connector from the USB ports.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
