メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Asus Eee PC 900 LCD Display Screen Replacement
必要な工具と部品
  1. Asus Eee PC 900 LCD Display Screen Replacement, Battery: 手順 1、 3の画像 1 Asus Eee PC 900 LCD Display Screen Replacement, Battery: 手順 1、 3の画像 2 Asus Eee PC 900 LCD Display Screen Replacement, Battery: 手順 1、 3の画像 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 LCD Display Screen Replacement: 手順 2、 1の画像 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 LCD Display Screen Replacement, Keyboard: 手順 3、 2の画像 1 Asus Eee PC 900 LCD Display Screen Replacement, Keyboard: 手順 3、 2の画像 2
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
  4. Asus Eee PC 900 LCD Display Screen Replacement: 手順 4、 2の画像 1 Asus Eee PC 900 LCD Display Screen Replacement: 手順 4、 2の画像 2
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
  5. Asus Eee PC 900 LCD Display Screen Replacement: 手順 5、 1の画像 1
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
  6. Asus Eee PC 900 LCD Display Screen Replacement: 手順 6、 1の画像 1
    • Remove the keyboard by lifting upwards.
  7. Asus Eee PC 900 LCD Display Screen Replacement, Top Cover: 手順 7、 2の画像 1 Asus Eee PC 900 LCD Display Screen Replacement, Top Cover: 手順 7、 2の画像 2
    • Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
  8. Asus Eee PC 900 LCD Display Screen Replacement: 手順 8、 2の画像 1 Asus Eee PC 900 LCD Display Screen Replacement: 手順 8、 2の画像 2
    • Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
  9. Asus Eee PC 900 LCD Display Screen Replacement: 手順 9、 3の画像 1 Asus Eee PC 900 LCD Display Screen Replacement: 手順 9、 3の画像 2 Asus Eee PC 900 LCD Display Screen Replacement: 手順 9、 3の画像 3
    • Flip the laptop back over and identify the touchpad ribbon.
    • Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
  10. Asus Eee PC 900 LCD Display Screen Replacement: 手順 10、 1の画像 1
    • Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
  11. Asus Eee PC 900 LCD Display Screen Replacement: 手順 11、 1の画像 1
    • Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
  12. Asus Eee PC 900 LCD Display Screen Replacement: 手順 12、 3の画像 1 Asus Eee PC 900 LCD Display Screen Replacement: 手順 12、 3の画像 2 Asus Eee PC 900 LCD Display Screen Replacement: 手順 12、 3の画像 3
    • Caution: To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage.
    • Remove the laptop cover.
  13. Asus Eee PC 900 LCD Display Screen Replacement, LCD Display Screen: 手順 13、 3の画像 1 Asus Eee PC 900 LCD Display Screen Replacement, LCD Display Screen: 手順 13、 3の画像 2 Asus Eee PC 900 LCD Display Screen Replacement, LCD Display Screen: 手順 13、 3の画像 3
    • Remove the large black wire using a plastic opening tool.
  14. Asus Eee PC 900 LCD Display Screen Replacement: 手順 14、 3の画像 1 Asus Eee PC 900 LCD Display Screen Replacement: 手順 14、 3の画像 2 Asus Eee PC 900 LCD Display Screen Replacement: 手順 14、 3の画像 3
    • Gently pry off the six rubber covers around the outside of the screen using a 2 mm flat head screwdriver.
    • A flat head screwdriver is preferable over a spudger as the spudger's head is not thin enough to to slip under the rubber covers.
    • Remove the six 4.76 mm Phillips #0 screws underneath each cover.
  15. Asus Eee PC 900 LCD Display Screen Replacement: 手順 15、 1の画像 1
    • Using a plastic opening tool, carefully detach the casing around the screen cover.
    • Remove the screen cover.
  16. Asus Eee PC 900 LCD Display Screen Replacement: 手順 16、 3の画像 1 Asus Eee PC 900 LCD Display Screen Replacement: 手順 16、 3の画像 2 Asus Eee PC 900 LCD Display Screen Replacement: 手順 16、 3の画像 3
    • Remove the four 4.76mm Phillips #0 screws located on the corners of the screen.
    • Lift out the display screen.
終わりに
15 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Michael Barker
メンバー登録日: 01/25/12
290 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S3G27
4 メンバー
16のガイドは作成済み
2 件のコメント
Another PERFECT iFixIt guide!
Had to replace the screen in one of these little beauties, and this walk-through worked like all iFixIt tutorials: Flawlessly.
Kudos Mr. Barker!
WildBill - 返信
Perfect guide, thank you.
Roberto Zoni - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 18
過去 30 日: 60
今までの合計 14,689
