Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
Identify the three metal tabs holding down the laptop's keyboard.
Using a spudger, depress each metal tab to remove the keyboard.
The upper part of the keyboard should "pop up" from its holder.
Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
